Quote: It's a pretty large port. I'd be willing to bet it'll hurt low speed TQ over the early casting. But with a higher rpm range, and good compression the late head should be much better!
it's gotta be all relative, as my '11 charger R/T doesn't feel like it's soft on the low end, even with 28.6" tires, 2.65 rear and 3.59 1st gear (so, equivalant first gear as a 727 with 3.8 rear gears and a 28" tire, or 3.66's and 27" tire)
long intake port runners
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
performance only racing, CRT, ultimate converter, superior design concepts, ThumperCarbs
