OK Quick question - I just pulled my stock 318 out of my '83 gran fury and when I removed the factory 90* oil filter adapter, there was NO gasket. This thing has never been off before. Is the gasket absolutely necessary between the adapter and the block?
I just went through the same thing with my diplomat. When I took the adapter off, there was NO gaskets, but now that I put it together again, it leaks badly. Does anybody know the size of the small cork gasket that goes on the bolt? I found the large round one at advance auto in stock already. I would order one, but I'm trying to get the car running ASAP.
