I am looking at buying this (new) crankshaft.
I've checked the spec-sheet etc from the seller and I am comfortable with it.
As I don't have a reference part to check against (it's in the US and I am in Australia), I need to check if the flywheel flange will work for my combo or I can make it work.
These are my only concerns & hopefully you guys can set me straight:
1. it doesn't have a step-register for flywheel .?.
2. doesn't have locating dowels for flywheel ? the bolts carry the entire locating load as well as clamping load is that ok?
Sorry about pic quality. if anyone has pictures of std Hemi forged crank flywheel flange it'd be appreciated. otherwise i may have to go down a custom flywheel route to suit this crank.
cheers, Darren
![](/ubbthreads/images/graemlins/beer.gif)
