Ok, I was rebuilding my 833, I have 2 overdrive tranny's to rob the wider syncros from.
The gears in my tranny were great but I wanted to use the newer syncros but the overdrive 3-4 hub did not fit the shaft. Is there 2 differnet hubs? Are there OD/non OD hubs?
Are the sliders different between the newer and older syicros interchangeable?
