Quote: Mr_P_Body-yes plenty of fuel. Mini starter is over 16 yrs old tho. Car had sat for 9 months.
While you'd like to see more than 8 w/ MSD I'm going to bet your gas is bad. Unless you used some gas stabilizer it's done. If you still have the stock or metal tank you probably have water in the mix too. I'd drain the tank and clean the line out. You can try and gravity feed the carb from a can of new gas to see if that's the problem before you go thru it all.
