I finally down loaded some progress pics. Aluminum drive shaft is here from Dyno-tech. Carpets done,wheelie bars are on,trans is built,motors almost done. During trial assy I missed with my initial piston to valve clearance. Had to go cut the pistons .035" on both notches. Crank end play is only .002."I'll either have to drill the cap or sand the thrust bearing. Intakes off getting trimmed . I'm still trying to be out in May.
Doug
