Re: B-body Exhaust
[Re: DUFFMAN]
#1206099
03/30/12 07:24 PM
03/30/12 07:24 PM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
Have you considered site sponsor Accurate Exhaust Products? They do currently list a 10% off sale. Looks like you'd be at around $648.00 if you go all the way with repo chrome tips out the back. The thing I like about Accurate is they have various Mopar test fit cars in which they test fit every kit prior to selling so the fit will be as close as possible.
The last "custom" system I had bent locally only cost $450, but I was hoping to avoid having to load up the car and haul it to the exhaust shop this time.
OK, last time I'll try to sell you on this idea but the TTI stuff is mandrel bent, 16ga aluminized tubing and is $538.00 (not incl mufflers, $620.00 with). You tell them the casting numbers on your manifolds and they ensure you get exactly what you need...EASY install in your own shop and you end up with a much better system for not much more $$$
that ebay linked system is certainly compression bent, no idea how or if it fits, etc. etc.
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
