The TP linkage and the shift linkage have nothing to do with each other.
First, the aftermarket carb needs a special throttle lever adapter (#20-7 for a Holley and #1481 for a Carter/Edelbrock) even if the linkage is correct. This adapter sets up the correct leverage ratio.
The TP lever doesn't need to be full back at WOT, just near full back.
The INTERNET, the MISinformation superhighway
