Quote: 08' 6.1 Tone Wheel: 4 Bolt Mtg.............31 Small Teeth, One Large Tooth
Same as my 5.7 with 3 bolts. So the 6.1 ring fixes the 6.4 problem but the toner ring does not come seperate you need to purchase a crank. Maybe a market for this item. Thanks Steff this is the stuff that really helps
