I have an MSD E-curve. Should work well with big block. It has built in rev limiter, electronic adjustable vacuum curve and timing curves. Just pop the cap and turn the dials with a pocket screwdriver.
Just don't use thier soild state coil with it (won't run). And it's a tight fit with an A-body and small block.
