I understand the jets, squirters and springs but whats a 6.5PV??
The Power Valve is what makes it work. W/ your solid lifter cam I'd run it for a while before you adjust that. Also you might need more than the 72-76, so start a tad higher... 76-80 maybe. I think the "standard" rule for PV selection is vaccum at idle divided in half?? so 10-12 at idle would give you a 5.5-6.5PV
Oooh I see said the blind man!
Thank you again for the info. Looks like I'll be calling my local parts man for some parts!
