Quote: Does anyone know of a reverse manual valve body shifter w/reverse lock-out that can be shifted from high gear into neutral?
I've been doing it with a Hurst 1/4 stick, but it's about time I change to something better. I just like to go into neutral past the finish line.
PPP shifter Look at picture
Hmmmm. Unless someone knows for sure, I'll have to call them. But it looks like it may require a special valve body. If not, it would need a pretty complicated and strong spring-loaded mechanism inside to actually shift the trans into neutral when the shifter is pulled all the way back.
Yes, you do need a special valve body that has a clean neutral after high gear.
