Matt, if you go the lino route, you might want to run a molding around the perimeter; keeps things from rolling off, and will keep the edges from curling up. Look for something with an L shape, aluminum, kind of like the old formica tops used to use.
Decided to go the vinyl sheet flooring route. Went to Home Depot and picked up a remnant more than big enough for 24 bucks. After I glue it down I'll get some aluminum angle for the edges and fire up the saw.
Some see the glass as half empty, some see the glass as half full. I just drink straight out of the bottle.
