I don't have any digital pics of mine to post, but could get some today. The main things to watch are the ridge of the outter wheelwell. It curves in to clear the back of the quarter panel,but the factory left lots of extra room you'll need. Take the outter out,split it where it will interfere,and weld a patch in the gap. Also be warned that if you maximize the distance you move the springs themselves in,they will likely hit the lip around the gas tank(deadblow fix) and force modification of the gas filler tube in the spring area. If you measure and fit everything to the max you can get a 315-60-15 M/Tdrag radial in and still be able to slide your fingers past both sides of it. http://i355.photobucket.com/albums/r461/FriedDonuts/P1000654-1.jpg Not the best pic, but you get the idea.
