A transmission in good shape will not clash and grind with oil in it.
I agree: Unless it is very cold, and you happen to be driving the car it is installed in.
I rebuild manual transmissions as a side hobby. Wear on the synchronizer collar and dog teeth comes from one thing: hard abusive shifting. No lubricant of any type will prevent that, changing your driving habits will.
Actually one more,driving with you hand resting on the shifter handle.
