I used a 7290 driveshaft end with the stock 7290 to 1330(maybe 1310, not sure of the proper Dana Spicer part numbers ) Hi Po solid center stock type U joint Mopar used that same type U joint on the stock production muscle cars back in the day that came with the Dana 60, 4 speed hemi cars and all of them that where assembled with the Dana 60 rear ends That Dana 60 pinion yoke has U bolt as the U joint retainer, not straps and bolts like the 8 3/4 have. All that being said if your starting from scratch including the driveshaft go with the 1350
