If you are starting from scratch you might as well use 1350 u-joints. A Viper is the only mopar that used a 1350 slip yoke with a 727 type spline and diameter.
go with the 1350
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
