First off, if you dont care about O.E appearance, I would start by looking at the world products block mopar sells. If you do car about appearance, look for a good older mopar performance block pre world casting. As far as aluminum heads, I would look for a set from mopar cast by edelbrock, not the earlier mopar castings. Ebay is your friend.
