Check fuses first. Probably the brake switch, looks like it is under the hood. See pic .
Directions to remove Brake Switch: Depress and hold the brake pedal. Remove the stop lamp switch (2) from it's bracket on the brake pedal assembly (6). To do so, rotate the stop lamp switch in a counterclockwise direction approximately 30 degrees from its proper mounting position. Pull the switch rearward and remove it from its mounting bracket. Disconnect the wiring harness connector (1) from the switch.
548 cu. in., Bill Mitchell Aluminum Block, CRT 727 auto trans, Alston Chassis. 8.981et at 149.46 mph. 1.204et - 60 foot, So Far....
