Could you guys give me a run down on machining prices? I need to know if a perspective shop is in the "ball park" for their work...which I've heard for years,is TOP NOTCH! Dynamic Speed & Marine..in Harrison Twp. Mi. Thanks in advance for your help!
I use "Automotive Machine Shop" based on Art's (From Mancini Racing) recommendation.
Jack did absolutely perfect work on my stroker motor, and for the whole job it was about $1100. That included line boring the mains, boring .030 over, clearancing for a stroker crank, cleaning the block, sonic checking it, and balancing the rotating assembly for me.
http://automotivemachine.net/
