Here we go again. Pinion up, no down, no up...down...up...
The trans is down, so the pinion goes up to be parallel. If the trans is down and the pinion is down it can't be parallel. Or is that wrong, right, wrong...right...
Rick, the suspension was loaded. It's a 4 post lift/hoist, what ever it's called.
2010 Black Challenger SE <> 3.5 V6 Custom Shift Knobs www.flameball.com Check It Out
