i've run a bg carb for a long time, and i've modified/ rebuilt dozens. generally speaking, they're very well made, and poorly assembled. you would not believe the things i've found. LOTS of metal, in almost every one. in the float bowls, in the main wells, everywhere. throttle blades upside down. jets cross threaded. every one i've touched has ended up working great after correcting the (numerous) problems.
for what is the good life if not doing things thoughtfully?
