All you need is a divider in the center of the bottom tank. Flows up through one half of the core, crosses over in the top tank and then flows down in the other half of the core. I'm not saying that's what's happening but it could work that way.
Good point but it makes me wonder how much of a restriction that path would create...And what would happen if, for whatever reason the water gets below a certain level...
