My timing is around 34* and so far I have not had to use my start retard.It has been starting fine also with 12.2 comp. Thanks....
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
