Ok, here is my dillema. I want to run a factory mopar style disc brake set up on my car with 10 inch rear drums and a 1969 B body manual master cylinder. Is there any simple type swap that I can do to make that happen? Im ok with running a 1970 and newer spindle, rotor and caliper set up. The issue is that I have to run a 1969 B body manual master cylinder for sure. Any help would be great
What I did was use the rotors,calipers, and lower control arms from a 70 B body. It uses a different sway bar and mount so the calipers don't interfere with outer mounts of the sway bar.
You need to use a master cylinder without the residual valve. I used the newer style Mopar master cylinder (the flat one, not the angled one)
