I've got an Aeromotive 2000 on my wife's car, it's way over kill but it's one of the best and I won't have fuel pressure or volume issue pushing fuel to the front of the car. I have 2 #8 fuel lines coming from the fuel cell to a Y and out is #12 into a #12 fuel filter with stainless steel element. #10 line to the carb.
On my car I'm running a belt drive, Enderle with their brackets. It's been on the car for about 14 years and works flawlessly. Fuel cell is in the front of the car so it's not working hard at all.
I have a buddy that runs the BG mechanical pump and it sucks the alcohol from the rear fuel cell and it's works great too.
I'm also a Klotz fan with MegaDart, been using it for about 14 years. IMO, it's hands down better that most of the other top-end lubes you see most people use.
But I use a full quart per 55 gallon drum, maybe I'm running too much since he's only using 1/2 quart.
Wade Metzinger 918-809-0987
71 Cuda 9.28@145 -1s, Pglide
68 Cuda 10.64@124 1.45 60's 318->390 eddys
Moparts discount code on WIX - moparts www.Filter1.com
