Chrome Wheel cleaner.... It's an acid formula & will loosen all sorts of stuff... Since acid is stored in a plastic bottle it obviously doesn't effect plastic...
Not all plastics are the same, "plastic" is a very broad category. Best to not assume that the storage bottle is the same material in the shroud. The bottle has different requirements for its job than a shroud.
Try Simple Green first. Amd then maybe a pressure washer.
The 12 Scariest Words in the English Language:
We are here from the Government and
we want to help you.
1968 Plymouth Road Runner, Hemi and much more
1968 Dodge Charger, 318 and not much else
1958 Dodge Pick Up, 383 and loud
1966 Dodge Van, Slant 6 and cool
