[quoteIf it is 1 of those chrome Mopar Performance Chinese specials...
Toss it in the dumpster, you can sand it, grind it, put multiple gaskets and layers of RTV it will still leak..
x10!!!!
I had one, filed the neck ifself, filed the housing, used right stuff, etc...it never stopped leaking. Total POS.....
I took a chance and tried the billet piece from Source. Never a drop.....
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
