Drill the hole as large as you can then install the easy out.From my experience the fitting locks towards the inner part of the hole because the cooler line hole is tapered like a pipe fitting.The less brass you have showing the better your chances with the easy out.If is the cooler fitting in the rear be VERY CAREFUL NOT TO CRACK THE CASE there is not much material back there.
