Quote: Thought they were all 1/8" pipe fittings in the case.
I did too till I stumbled across one (brass) that was larger. No sure if it was OE or not but if those 2 enter/exit points just inside the case itself ain't restricted to less than the fitting ID I'd think the larger ones w 3/8" lines/cooler would give more flow
