BTW- I do plan on having the rods reconditioned with new bearings and ARP bolts since that is cheap and easy. The crank is very nice and just needs a polishing for now.
I typically always go for the full rebuild and use moly rings. This is the first engine I am building as a "re-ringer", so what are the recommended rings?
