Sharpen a steel rod to use as a punch.. Punch a hole in the filter & drain it before you unscrew it.. I use a piece of a plastic bottle to direct the oil were I want it to go... Then as you unscrew the filter drop it directly into a ziplock bag...
"The Armies of our ancestors were lucky, in that they were not trailed by a second army of pencil pushers."
