I'll have to check block out as far as roller or not.crank is still in bearings I checked were o.k just saying I don't want this to snowball into a $1000 rebuild.was planning on changing bottom end 1 at a time not totally dismantaling the engine if you follow me.there is a small ridge nothing alittle scotch brite won't clean up I think. thanks,nate
Trucks/cars there all MOPARS 98 w2500 cummins24v5spd 85 w350 crew/short360 78 w150 shortfact.440 with upgrades 87 w150 soon to be new snowfighter 75 duster.... project since1999... never to be completed
