The front end doesn't clunk going over bumps, front end is very tight and responsive. It only clunks in the right front tire area when your stopped and turning left, and will only clunk loud once. Front end can't have 5k miles on it. Firm Feel arms feel nice and tight. No movement with pry bar under tire with lca loaded. Shocks feel tight. Driver side lca bushing has some tearing, it should be replaced but I think the noise would be coming from drivers side.
Maybe the right upper ball joint is defective?
