Nothing wrong with a stock crank. I made upwards of a thousand 10.60 passes in my 3,000 lb dart before it went into my buddies car for several seasons he spun a rod bearing not the cranks fault. I have also run cast 318 cranks in the same car in the 11.10 10.90 range.
LA as in Cajun country? Or LA as in Hollywood?
I know a guy from Louisiana that said he had some quick 318s. Coincidence?
**Photobucket sucks**
