J,
If you had any tallent we could get 380 out of a set of B1-BS's.
p.s. another very quick street car is going to rumbling around the Carson area this summer. W9 440 in an A-body
Is that 440 block a 59* lifter bank angle block? I ask b/c I have a set of fully ported W9's for my R1 block but the 59* block with it's 1.875 lifter bore spacing makes me nervous with the push rod angle.. I know I can run the offset rocker but the little 5/16 push rods is less than desirable for my boosted application.
