OK> I have run the OBDII on the motor and come up with the following codes, P0101, P0108, P0104, P0102, and P0110. I have sent the computer off and had it flashed to removed anti theft and reinstalled it. The motor didn't behave any different. It would crank but not turn over. I checked the fuel pressure and it was down around 10psi. I ran a wire straight off the battery to the fuel pump and it jumps the pressure up to 58 psi. I confirmed the voltage drop to the computer when the key is in the START position. I took the same wire that I ran directly off the battery to feed the pump and also fed 12V straight to the computer. Now the motor turns over and runs for a second at very high RPM then tries to stall out but before stalling out revs back up again for a second then dies.
![](/ubbthreads/images/graemlins/shruggy.gif)
