I do the full time oiling on any motor that has a solid roller cam I do it for additional oiling and cooling to the valve springs I have seen several BB Mopars really flood the top end without retricting the feed
I have a 499/400 with full time oiling and I restricted the block with a .100 orfice and it still floods the top and goes out the breathers. I'm doing a .040 next
E. Williams 65 Coronet 500 3400lbs w/d, 446, Indy EZ'S, A&A transbrake,Comp 650 lift cam, 6.50 @ 105 mph 1/8th 10.25 @ 130mph 1/4
