if you look at the cam bearings hole alignment to the block passage and the design of the oil passages in the #4 cam journal the factory design already has restriction built into it. keep in mind that the #4 cam journal's oil passages only have a brief alignment with the block passage every 720 degrees of crankshaft rotation.
