A lot of engine builders now are running the second ring gap at a couple thou larger than the top ring gap to reduce ring flutter... if it got past the top ring you dont want to hold it back and cause any flutter to both rings.... this is what I've been doing for some time now
that makes sense
have you noticed any differences since you started doing this?
I know one of the best Hi Po machine shops and high end engine building shops in SO CA that use the 2nd gap bigger(.002 to .004) than the top gap policy I have also for the last ten years I started that when TRW, Speed Pro started recommending that procedure
