Gene is the only source for repo elastometeric bumpers
Correct, and if you want some it would probably be a good idea to get some sooner than later, he's not getting any younger. Do yourself a favor and buy 1970 versions, they all start that way and Gene cuts the 70's to make them 71 versions. You'll probably do a better job if you do it yourself. As far as fit and accuracey they are pretty darn correct although I noticed the rears might need a SMALL amount of trimming/width adjustment
