I just recounted it again and it is 130 tooth
It did come with a pressure plate and disc.
The clutch measures 11" and bolts up to this flywheel and the disc fits slightly inside.
What is a scalloped clutch?
So if it is for a cast crank 383 will it work on a cast crank 340 1973
