The old school general rule of thumb was to shift about 10% over peak power anything more and you are twisting the motor for no good reason.
If it were mine I would put it on a good chasis dyno at a reasonable ambiant temprature in a good state of tune with good gas in it and see where generally peak power is. Then shift 10% above that number. Just IMO 2 cents worth.
