why don't you make what Don's at FBO is making with the "Brand new "Mopar" Ecu module"?. Find some old ECU, remove the inners and fit inside the HEI, module, using the stock 5 pins ECU plug
With a Charger born in Chrysler assembly plant in Valencia, Venezuela
