got a new one...
never ever break the first rule of engine building...mock up and measure everything twice before final machine work/balancing. or you might find out that pistons advertised as having a .050" dome and expected to stick up .030-.040 past the deck on an uncut block, actually stick up above the deck .083" and then find out that the piston manufacturer changed the piston 3 years ago, but never changed the online description/specs, etc.
DON'T ASK ME HOW I KNOW!
