Pic of pushrod cup oil holes. With the supplied adjusters the upper adjustment would be with the adjuster flush with the lower part of the rocker arm body. It look like you may only have 2-Turns (maybe 3 max?) of adjustment down from there, So correct length pushrods are required. The stainless bodies are bushed, and the roller does not seem loose.
I run ProComp rockers that had these same adjuster studs in them when I got them. after breaking a second one of them because of this limited adjustability, I called ProComp and talked to them about the issue. They agreed that this design was flawed, and had changed the design of this component. They were happy to send me (16) new studs, that were of a much better design.
LemonWedge - Street heavy / Strip ready - 11.07 @ 120
