Lets say that the application is a 340-6 AAR Cuda.
I know there is a plastic clip that holds the (+) cable to the shock tower, but is there also a metal (rubber dipped?) clamp that bolts to the drivers inner frame rail?
If so, it would be held on by a bolt.... should there be a welded nut on the inside of my frame rail?
Here's a pic of what I am thinking the clamp looks like...
