70 Cuda - Frame rail (+) battery cable clamp location? #1112161
11/12/11 02:03 PM
11/12/11 02:03 PM
Houston Texas
PAINT IT BLACK Offline OP
Got a CHIP on my shoulder
Houston Texas
Lets say that the application is a 340-6 AAR Cuda.
I know there is a plastic clip that holds the (+) cable to the shock tower, but is there also a metal (rubber dipped?) clamp that bolts to the drivers inner frame rail?
If so, it would be held on by a bolt.... should there be a welded nut on the inside of my frame rail?
Here's a pic of what I am thinking the clamp looks like...
Re: 70 Cuda - Frame rail (+) battery cable clamp location? [Re: PAINT IT BLACK] #1112162
11/12/11 07:12 PM
11/12/11 07:12 PM
Houston Texas
Houston Texas
Come on guys...
Re: 70 Cuda - Frame rail (+) battery cable clamp location? [Re: PAINT IT BLACK] #1112163
11/12/11 08:24 PM
11/12/11 08:24 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Re: 70 Cuda - Frame rail (+) battery cable clamp location? [Re: gtx6970] #1112164
11/12/11 08:25 PM
11/12/11 08:25 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
2
Re: 70 Cuda - Frame rail (+) battery cable clamp location? [Re: gtx6970] #1112165
11/12/11 10:37 PM
11/12/11 10:37 PM
Richmond, VA
rayztoy Offline
rayztoy  Offline
Richmond, VA
Mr. Bill to the rescue...
Re: 70 Cuda - Frame rail (+) battery cable clamp location? [Re: gtx6970] #1112166
11/13/11 01:01 AM
11/13/11 01:01 AM
Houston Texas
Houston Texas
hmmm. Bill you have a pm.
