Re: Real A body 4" BC axles, anyone make?
[Re: Dart 340]
#111116
08/27/08 04:00 PM
08/27/08 04:00 PM
Posts: 75,089 A Banana Republic near you.
JohnRR
my understanding was they are not built to spec.
a large bolt pattern is not built to a body specs , the offset of the axle flange is different to accommodate the larger body brake setups , but it makes zero sense for any company to make a small bolt pattern axle that will not fit a body offset spec , the only SILLY thing i can think of is the axles being too short because of the green bearings CAUSING an issue.
Entire Thread
Dart 340
08/27/08 04:11 PM
Moonraker
08/27/08 04:25 PM
Dart 340
08/27/08 04:43 PM
JohnRR
08/27/08 04:30 PM
Dart 340
08/27/08 04:42 PM
JohnRR
08/27/08 04:44 PM
DoctorDiff
08/27/08 04:50 PM
Dart 340
08/27/08 05:56 PM
MoparforLife
08/27/08 06:01 PM
Dart 340
08/27/08 06:03 PM
JohnRR
08/27/08 08:00 PM
Moonraker
08/27/08 05:21 PM
Dart 340
08/27/08 06:00 PM
DoctorDiff
08/27/08 07:35 PM
