One set has a bunch of gashes on them from the last owner who had troubles removing the bearing retainer collar, the other set has studs that won't
stay in place and they were even welded in. Might see if I can open the holes up and press in larger moser studs. I think it was due to his using ARP studs with rims that did not support them right.
